Case Modding: Moving the power, reset buttons and LEDs
Hi there,
I just ordered a Thermaltake Shark which has all that I am looking for
except that the power, reset buttons and LEDs are behind the door.
Has anyone ever relocated these items to a new place on their case.
For me, I want to move them to a location on the "outside, top, front"
so I do not have to keep opening and closing the doors and they are
in easy reach when the case is put on the ground.
Many thanks.
4 answers Last reply
More about case modding moving power reset buttons leds
  1. yes it can be done, i just moved mine to my side panel, (i have my case on my desk) i even moved my cdrom eject button there too!
    you'd be better buying a new switch, i bought mine that had LED's inside the switch so i have power and disk acces flashing buttons :)
    you want push-to-make switches something like this
    http://www.maplin.co.uk/Module.aspx?ModuleNo=34861&criteria=Push%20Switches&doy=3m2
    hope this helps
    Don
  2. wow, there isn't one thing not on the internet :)
    i just ordered the Lian Li PC-V1100B Silent plus. The one thing that almost made me change my mind is that it doesn't have a reset button. Seems like were going backwards in technology when you leave that out, then take a way pci slots on a mb.... but i know there's a reason for it all and thats why im glad to come across this thread. My point, could i use one of these buttons as a reset button on my new case? and what tools will i need to install it?
    thanks
    Pure529th
  3. Quote:
    Hi,
    Use the 2 wires from e.g. an old system speaker, saving the connector. solder it onto a button like the one above. Then drill a hole were you want it. Fasten the button and connect to mobo. Voila!
    Good Luck!
  4. My buddy, he just used a light switch, it was ghetto rig. I still give him shit about it, he likes it because people at lan parties would just laughed at it. But it works and makes him look stupid noob. hahaha :D
Power Supplies Cases Modding Power Thermaltake Components
