Tom's Hardware > Forum > CPU & Components > CPUs > PC power and temp monitors!
Forum CPU & Components : CPUs - PC power and temp monitors!
Hey guys do you know any good free programs that can do performance tests and monitor my temps on my pc? I hear PC wizard is a good one and simple to use. You guys got an other good or better programs? :twisted:
Sponsored Links
LOL i have posted a thread with the exact same question...i switched from probe to SPEED FAN cuz it shows the temperatire in the taskbar :p
they are all accurate imo.
Reply to style69
- 0 +
The first thing you want to do is check with your motherboard manufacturer or the CD that came with your motherboard.
Reply to dhlucke
- 0 +
For that mobo, MBM5 should be fine. For benchmarking, try Sysoft sandra, aquamark, and check out futuremark's various progs.
Reply to endyen
check out www.majorgeeks.com, there are plenty of freeware benchmarking and monitoring software.
Reply to chuckshissle
And why do they have so much cool stuff? Because they're major geeks. :D
Reply to slvr_phoenix
There are 1334 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
