Using onboard audio, the sound kicks in and out of 1 side of my headphones, depending on how I tilt my head, regardless if I switch to a different pair of headphones, is it the soundcard ?
first i have the same prob with mine.second it's probably the headphones what kind you got(i got cheap ones they never worked). (stupid outsourcing)third you have onboard sound does it work with speaker's?
Ya I have logitech z2200 2.1 speakers and they work just fine, no problems there, i'm using two different types of headphones both with the same cutting in and out of one side of the headphones depending on the way I tilt my head. I use sony MDR-013 and a some pansonic earbuds, i'll try some other headphones just to make sure.
If you're using the front jack w/ the headphones, try the back jack (where your speakers are plugged in). It may be that the wires that hook up to the front got loose or something.
ah yeah the tilting the head trick, I wrecked many good head phones doing this.
seriously it may be the master volume isn't set right and you might have the pan L/R off center. Check this in the Mixer settings of the sound card.
If you open up the audio master controls check to make sure your pan settings are dead center and that the left or right is not muted out.
If you can't find nothing wrong there then check the connections on the head phones.
If that doesn't do it test the head phones in another device not on the computer. If they work there, it's the port you're plugging into or interference from something around there.
Not to sound like a smart ass but what the heck would pan/balance have to do with the sound cutting in and out when he tilts his head. Did you even read the posts?
ITS SO OBVIOUS he has a bad connection on the computer since he has tried different head phones. That or both headphones have the exact same problem.
bugmenot:
When the headphones are plugged in move the connector around and I bet the sound will kick out. Do what nobly suggested, and check the connections on the motherboard.
