hi, ı have just changed my mobo and video card tonight and ı will go crazy. here is the story:
my old mobo was an Epox 9NDA3I(agp) and my 3200 venice was runing at 2.4 at 1.37-1.41 voltage (default setting) and the heat was idle:34 load:39
my new mobo is an EPOX 9NPA3J nforce4 pci-express now all settings at default like the past but the mobo sets the voltage 1.48 (setting:auto) so the heat is idle:41 load:46 ı've checked the termal paste twice. no problem with it. Do you have any idea about what the fuck is going on?
Is the voltage and heat change normal? ı mean is it possible that the voltage and heat change according to your mobo and video interface? you know this damn 3200 should work between 1.35-1.40 but even at stock settings(2.0 ghz) with this mobo the voltage is at:1.49
please give me some advice
