When I'm using headphones theres weird buzzing and other little sounds when moving my mouse or on loading screens of games. It also happens when scrolling up or down web pages. I'm using a Logitech MX 500 USB mouse and I have a Soundblaster Audigy 2 ZS sound card. The noise is still there even after I check the Mute All button on the volume control. Can someone give me an answer on how to fix this or a logical explanation why there's sound when the sounds are all muted? This is driving me nuts becase its not going away and persists while I play games and its especially annoying when scrolling up and down web pages.
try turning off or muting all the different inpurts one at a time. I get feed back when I have the cd volume turned on. Mute it and it all goes away. You can also leave the ones you dont use at all muted while your at it.
I did that already. Theres still little noises like I mentioned.
I muted all of these at the same time and its still there:
Play Control, Wave/MP3, MIDI Synth, S-PDIF In, CD Digital, Auxiliary, CD Audio, Line In, TAD In, and Microphone (and the Microphone +20dB box is unchecked).
I'm going to update my Sound Card driver and see if that does anything. Probably not......I have a feeling its some kind of interference that can't be helped.
you're picking up interference from something near by.
Could it possibly be because I'm using a surge protector?
Hmm.....I do have a lot of electronics upstairs in the rooms near this room with the computer. In my room alone I've got a TV, VCR, Stereo, Satellite Radio, Xbox, and Dreamcast. My parents have a TV in their room.
I wish I knew how to find out exactly what the cause of this is.
Im having this exact same problem and Im using BRAND NEW headphones so its NOT a wire problem, Im using SB audigy.
These didn't help me but maybe they'll help you. They're the best I could find related to this problem. It seems a lot of people have this problem or variations of it.
no I doubt this would come from a surge protector, but everything generates a certain amount of interference. Usually it's not enough to bother other devices.
All you can really do is start unpluging stuff until the noise goes away. The noise could be coming from waves in the electricity lines or something maybe plugged into that same circuit.
You ever seen the effect of turning a vacuum cleaner on and the static on the TV? That's the best description I can give. But that's the only logical reason for it.
good luck.
Yeah I know what you mean. It would be a pain in the ass to start disconnecting stuff so I guess I'll just deal with it.
