Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > 3-pin or 2-pin Power LED connector?
Hi, I just built my first PC from scratch. Everything went well except one thing...
The cable for my case Power LED is for a 3 pin connector (but the middle hole is not connected to a wire) but the connector for the Power LED on my MB are only 2 pins!
What can I do to be able to connect my Power LED? Is there some type of adaptor or do I have to re-wire it or something (which by the way I know nothing of how to do)?
Sponsored Links
you'll have to rewire it, I had the same problem a couple years ago.
Probably the easiest way to find this kind of plug would be to google it.
Or just skip it as you really don't need it, you can tell the system is on by the whir of the fans.
Reply to pip_seeker
There are 518 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
