Tom's Hardware > Forum > Smartphones & PDAs > Windows Mobile > REMOTE ADMIN PC - best soft ?
Forum Smartphones & PDAs : Windows Mobile - REMOTE ADMIN PC - best soft ?
Archived from groups: microsoft.public.pocketpc (More info?)
what the best remote admin soft for pocket?
(with this soft i must see the desktop of pc on my pocket)
thx
Sponsored Links
Why not use Terminal Services Client that already comes in the Pocket PC?
Helio Diamant - MS/MVP Mobile Devices
http://www.pocketpcfreak.com
"Disperso" <disperso@disperso.disperso> wrote in message
news:3ge3d.6188$LV3.8320@nntpserver.swip.net...
> thx
Reply to Anonymous
i've tried (windows Xp pro) but not non function.
how i can activate the terminal service on XP ?
"Helio Diamant - MS/MVP, Mobile Devices" <helio@nospam.pocketpcfreak.com> ha
scritto nel messaggio news:OPLEnFknEHA.3460@tk2msftngp13.phx.gbl...
> > thx
Reply to Anonymous
You can use the built-in Terminal Services Client if the PC you want to control is running XP Pro
Remote Desktop or is a Windows 2003/2000 Server running Terminal Server.
If the desktop PC is running some other flavor of Windows or LINUX, then VNC is an alternative. Get
the Windows VNC server software from...
http://ultravnc.sourceforge.net/
The LINUX VNC server software is part of most, if not all, current LINUX releases, ie. like Red Hat
9 for example...
PocketPC VNC client software...
http://www.allware.com.mx/Windowsce/
http://www.cs.utah.edu/%7Emidgley/wince/vnc.html
Al Jarvi (MS-MVP Windows Networking)
Please post *ALL* questions and replies to the news group for the mutual benefit of all of us...
The MS-MVP Program - http://mvp.support.microsoft.com
This posting is provided "AS IS" with no warranties, and confers no rights...
> thx
Reply to Anonymous
Look at this page for help enabling Remote Desktop on an XP Pro box...
http://www.microsoft.com/windowsxp [...] emote.mspx
....or...
http://www.microsoft.com/resources [...] m_huxe.asp
http://www.microsoft.com/resources [...] m_hzcq.asp
Note that if your running XP Pro Remote Desktop behind a firewall/NAT/router then you also need TCP
Port 3389 open...
news:8If3d.6208$LV3.8256@nntpserver.swip.net...
>> > thx
Reply to Anonymous
remote access actived, firewall disabled but it not connect.
(i connect by bluetooth and ping pc is ok)
"Sooner Al" <SoonerAl@somewhere.net.invalid> ha scritto nel messaggio
news:%237TfJtknEHA.2612@TK2MSFTNGP15.phx.gbl...
> 9 for example...
rights...
> > thx
Reply to Anonymous
You will not be able to use Terminal Services to control an XP PC over BT if
the XP PC is the one that you have a BT connection with. Remote desktop only
allows one user on the desktop, that user is logged off when you log on with
TS, and that closes the BT session. You can control a different XP Pro PC
over BT than the one you are connected too.
I am not sure if this happens with a WiFi Adhoc connection to the PC, but it
certainly doesn't if the PPC is connected to the network via an AP.
Sven, MS-MVP Mobile Devices
news:k9g3d.6213$LV3.8361@nntpserver.swip.net...
> > 9 for example...
> rights...
> > > thx
Reply to Anonymous
you say that i can't use terminal service for access desktop?
in this case which software can i use?
(besides vnc for pocket)
"Sven, MVP-Mobile Devices" <sejohannsen@hotmail.com> ha scritto nel
messaggio news:uQRwS$lnEHA.3520@TK2MSFTNGP11.phx.gbl...
if
only
with
it
to
Server.
then
LINUX
> > > 9 for example...
mutual
> > rights...
> > > > thx
Reply to Anonymous
You can't use terminal services over BT to control the XP desktop to which
the BT connection is made. VNC is the only other option I know of and I
can't confirm that works under the same conditions.
news:v%j3d.6304$LV3.8370@nntpserver.swip.net...
BT
> if
> only
> with
PC
but
> it
> to
> Server.
> then
> LINUX
> > > > 9 for example...
> mutual
> > > rights...
> > > > > thx
Reply to Anonymous
- 0 +
Terminal Services gives you another login. It does not "share" the
desktop. So, if you want to be able to log into the XP box, Terminal
Services is your choide. However, if you want to "see" the remote
desktop (user already logged in), then VNC is your choice.
> if
> only
> with
> it
> to
> Server.
> then
> LINUX
>>>>9 for example...
> mutual
>>>rights...
>>>>>thx
Reply to Dan
However, XP Pro only allows one concurrent login. When you login from the
terminal services client, it logs off the current user, killing the BT
connection, if it is to that machine. That's the issue.
"Dan" <dbrussee@nc.rr.com> wrote in message
news:414DF081.5030102@nc.rr.com...
BT
> > if
> > only
> > with
PC
but
> > it
> > to
> > Server.
> > then
> > LINUX
> >>>>9 for example...
> > mutual
> >>>rights...
> >>>>>thx
Reply to Anonymous
dont' know why ..but vnc-pocket successful connect and after fast
disconnect...
i'm work on it but if you have another software title advise me
thx
"Dan" <dbrussee@nc.rr.com> ha scritto nel messaggio
BT
> > if
> > only
> > with
PC
but
> > it
> > to
> > Server.
> > then
> > LINUX
> >>>>9 for example...
> > mutual
> >>>rights...
> >>>>>thx
Reply to Anonymous
Because VNC allows you to control the PC maintaining the current login.
Terminal services run against XP Pro's Remote Desktop allows Remote login to
that PC, logging off the current user.
news:A%n3d.6360$LV3.8331@nntpserver.swip.net...
> disconnect...
> thx
> BT
> > > if
desktop
> > > only
on
> > > with
Pro
> PC
> but
> > > it
> > > to
> > > Server.
> > > then
> > > LINUX
> > >>>>9 for example...
> > > mutual
> > >>>rights...
> > >>>>>thx
Reply to Anonymous
- 0 +
Hi,
Could try our VNC client: PTvncGPRS from Handango or Pocketgear.
There is a trial version of PTvncGPRS and you can view and control
your PC from your PC via Bluetooth, USB cable, WiFi or over the
internet (eg. GPRS).
bye
Dave (Parys Technografx)
> disconnect...
> thx
> BT
> > > if
desktop
> > > only
on
> > > with
Pro
> PC
> but
> > > it
> > > to
> > > Server.
> > > then
> > > LINUX
> > >>>>9 for example...
> > > mutual
> > >>>rights...
> > >>>>>thx
Reply to Dave
- 0 +
That should have been:
"you can view and control your PC from your PPC"
"dave" <dave@parystec.demon.co.uk> wrote in message
news:cim5sm$b9$1$8300dec7@news.demon.co.uk...
> Hi,
> bye
> > disconnect...
> > thx
over
> > BT
> > > > if
> desktop
> > > > only
> on
> > > > with
> Pro
> > PC
PC,
> > but
> > > > it
messaggio
want
> > > > to
> > > > Server.
LINUX,
> > > > then
> > > > LINUX
> > > >>>>9 for example...
> > > > mutual
no
> > > >>>rights...
> > > >>>>>thx
Reply to Dave
There are 988 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
