I need some advice about a major problem with my new(ish) computer.
It is 6 months old( i bought from a 'we'll make it for you' website which has since gone bust...) , and the processor is an AMD Athlon 64 2800. I'm not sure of the details about the motherboard or hard drive, but could probably find out.
I have been told by a computer repair person that it "sounds like" a hard-drive problem, which is why i'm posting in here.
So basically, every time I turn on my computer, within 5-10 minutes it crashes to a Blue Screen Of Death. These are often different, sometimes 'Irq_Not_Less_or_equal' sometimes 'Memory Management' and other such wonderful messages.
If I then turn my computer back on again after a crash, it might get halfway through starting up then crash again. Then if i try again it will usually just make whirring noises but not actually try to start up. It usually needs a few hours(at least) before it will then work again.
I have checked to see if it is overheating, but it doesnt look like it. The air coming out of the fan at the back is not THAT hot, and all the fans inside seem to be working OK.
I have tried diabling the L1 and L2 caches, as it sometimes advises me to, but that did nothing. it has recently started advising me that my BIOS needs re-installing, but I have NO IDEA how to do this, or what this means. (in case my fears are true, i have no floppy-drive, which i suspect is what BIOS is installed on).
Some-one also suggested that I format the hard-drive, but I don't think I will be able to, as it takes longer than the amount of time the computer ever works for.
It also sometimes recommends that I re-install drivers, which I have tried doing using the CD which came with it. This either did nothing, or crashed before the installation was completed.
If anyone has any suggesdtions about what I should try, or advice on what I could do, please post telling me. Seriously, i'm desperate!
Thanks
Thanks
