Tom's Hardware > Forum > Windows 7 > Configuration & Customize > 32bit installation path on 64bit
Forum Windows 7 : Configuration & Customize - 32bit installation path on 64bit
Hi,
Hopefully a very simple question. I am running Win7 HP 64 bit and have noticed that when i install 32 bit app, the default installation path ins C:\Program files (x86)\...
My questions is: Will changing this make any difference ie: instead of installing to this location to change it to C:\Apps or C:\games etc
May thanks for your helps
D
Sponsored Links
There is a subsystem in (XP/Vista/7)x64 called "WOW64" - This stands for "Windows on Windows x64". What it does is provide a 32 bit execution path within a 64 bit environment.
How that works is: On the processor side, 32 bit binaries execute natively - so overall speed is unaffected. On the OS side, there needs to be native 32 bit libraries for the 32 bit apps to execute against, as well as the facility to transparently track and play traffic cop with the various 32 bit code paths and registry entries so they're kept separate from 64 bit ones.
So, as the name implies, you essentially have a 32 bit version of Windows running inside a 64 bit version of Windows.
I strongly recommend you do not change the installation paths.
------------------------------ Which Chip? Well, it depends on which set of thieving b@stardz you choose to support: The ones who use insider trading to enrich themselves while running their company into the ground, or the ones who illegally pay vendors to not support the first group.
Reply to Scotteq
Many thanks for the reply - so would this also hold true if i decided to install game to my 2nd HDD. eg: "D:\Games\..." would i have to put i have to put "D:\Games (x86)\..." or is it simply a case of wherever windows decides to install it is where it has to go (this would be annoying) as i have only 250Gb for my main C: drive.
Thaks again.
Reply to caimbeul
- 0 +
It won't hurt you to run the game from elsewhere - I have a couple games installed on other drives for the same reasons.
Reply to Scotteq
- 0 +
It actually doesn't matter what folder you install your programs to - for 32-bit programs WoW is used based on information in the EXE file headers, not based on what folder the program is in.
It's handier to use the default install directory because that's where people expect to find things, but if the application is written properly then you should be able to install it in any folder regardless of whether it's a 32- or 64-bit program.
Reply to sminlal
There are 1270 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 torbee won the Freshman badge
  • 01:00 dba won the Uniformed badge
  • 01:00 LoveMyslf won the Uniformed badge
  • 01:00 survdirt won the Uniformed badge
  • 01:00 vgigolo won the Uniformed badge
  • 01:00 alex3003 won the Uniformed badge
  • 01:00 dindarloo won the Uniformed badge
  • 01:00 Akash Nain won the Uniformed badge
  • 01:00 greeneman510 won the Uniformed badge
  • 16:28 bilbat won the Motherboards badge
