Is this a PSU problem?
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Is this a PSU problem?
Hello:
Last week my PC started shutting off every so often.. then to the point where it would shut off right after it was booted- then to the point where it shut off right after post screen. The only way to get it to power on a little is by turning toggle switch on PSU off, and then on- then try to power system up, where the same problem occurs. At first I thought that perhaps there had been a motherboard failiure related to bad capacitors, but I ruled that out last night after swapping in a brand new mobo and the same problem occurs. (In a way that is a relief, as the HDD's are SATA RAID 0 and I don't have backup of all the data.)
Could this be a power supply issue? With the motherboard ruled out and no beep codes to suggest a memory or processor issue (processor fan is working nicely), I can't think of anything else but the power supply that could be causing the problem.
Right now, it would seem I should be able to swap in a new PSU, put the original ABIT IC7-MAX3 back in and I should be able to boot right back up with no problems... BUT.. I think I might sacrifice drive speed and promote backups by going to RAID 1 at some point.. as this was a headache.
Thanks!
Sponsored Links
Then, hook up that suspecious psu to a good pc and try it there.
Memory could be bad and have errors.
Post your system specs, it would help a lot.
Reply to chuckshissle
- 0 +
Quote :
D'OH! Good suggestion.. actually have another PC in the house with which I could swap PSU's. I'll try that tonite.
Reply to msu97
You don't have to remove the psu of the good pc. Just take out the bad one and just plug it on the good system through the side. Save time.
- 0 +
:D was definitely the power supply- replaced it at system booted up as good as new.
Reply to msu97
- 0 +
Quote :
Glad to hear it. I am experiencing a similar problem and have a new PSU on the way.
Reply to sirak
Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Is this a PSU problem?
There are 1247 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
