Tom's Hardware > Forum > Windows 7 > Windows 7 General Discussion > [Solved] Will Win 7 64bit work with all my old games?
Forum Windows 7 : Windows 7 General Discussion - [Solved] Will Win 7 64bit work with all my old games?
Best answer from Scotteq.
The title of the thread says it all... I want to be able to play all my old games without having any issues. Last time I tried Vista 64 bit I had too many compatibility issues and ended up re-installing XP Pro.
I play BF 1942, BF2, CoD 1,2, United Offensive and CoD4.....
Am I good to go if I decide to get the 64bit version or do I need the 32bit version?
------------------------------ 550 @ 4.0 Ghz 1.425v
BFG GTX 260 (216)
4GB G.Skill @ 960MHz
Thermaltake TP 850w
I don't have those games, so there's no way I can say they do or don't work. But here's a thread on SevenForums tracking games that work/don't work for the RTM version of Win 7: http://www.sevenforums.com/gaming/ [...] ility.html
Hope that helps.
Sponsored Links
64Bit is compatible with 32Bit..
I can CoD 1,2, United Offensive and CoD4 on Win7 32Bit..
------------------------------ -Medo Egyptian
"Simplicity is a mix of complexity."
Reply to psycho sykes
so that means I should not have any issues correct?
Should I go with 32bit since I will only be using 4GB or just go ahead and get the 64bit?
BFG GTX 260 (216)
Thermaltake TP 850w
Reply to OvrClkr
Well, Wait till you upgrade your system and get the 64Bit version.. But for now i say stick with 32Bit or at least give it a try to see if it works.. Have you tried the RC when it was released?
Nope, I have had XP for a while... I tried Vista 64 but it was pain in the arse and I ended upo reinstalling XP. My problem is with my old games, as long as the OS can run them without any issues im fine.
BFG GTX 260 (216)
Thermaltake TP 850w
Reply to OvrClkr
Best answer
Hope that helps.
Message edited by Scotteq on 11-05-2009 at 10:32:27 PM
------------------------------ Which Chip? Well, it depends on which set of thieving b@stardz you choose to support: The ones who use insider trading to enrich themselves while running their company into the ground, or the ones who illegally pay vendors to not support the first group.
Reply to Scotteq
Thanks man!!!!
That answers my question =)
BFG GTX 260 (216)
Thermaltake TP 850w
Reply to OvrClkr
There are 1051 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
