Tom's Hardware > Forum > CPU & Components > Other Components > LCD TV/Moniter problems
Forum CPU & Components : Other Components - LCD TV/Moniter problems
OK! I have a 27 inch LCD TV/Monitor now in order to even consider doing this what graphics card could handle a resolution that big?
Sponsored Links
That would be an sli/crossfire like 7800,x1800andx1900. It's cool to have a big monitor if you have the graphics card to back it up for gaming.
Reply to chuckshissle
Sorry, I didn't quite catch what the problems are. I'm still not sure what your situation is. Do you already have the 27" TV/Monitor? If so, what brand/model? Is it widescreen? What is the native resolution?
What do you plan on using it for? Gaming, watching DVDs, internet surfing, or word processing?
It's very likely that any of the newer graphics cards will do just fine... any NVIDIA 6800 might be fine for you.
If gaming is your thing, then you shouldn't wory about which Video Card to get, because the latency of the LCD screen won't keep up with the frames per second provided by even a mid range video card.
Games look great in the widescreen format, but LCD screens always look blotchy when there's a lot of motion on the screen.
Reply to SciPunk
Thanks for the information, now my consern is how much is an SLi/Crossfire going to kill my wallet? lol
Reply to KhaoticOne
its a RCA 27" widescreen - unfortunatly i do not have the native rez on the LCD i just resently purchased the monster.
It (hopefully) will be used for gaming if the quality does suck
Reply to KhaoticOne
Hmmm Ok, how much was the monitor? If it was under $1k, I'm going to bet that the native resolution is probably about 768x1024.
In which case, a mid-range graphics card might do ok? I'm not sure on that point, but from what I've seen looking at TVs (I had the same idea as you), the native res is pretty low since its an LCD TV.
Look it up before you spend tons of $ on a graphics card that might be overkill.
Reply to nobly
Thanks for the help im new to the custom computer seen - I just barely starting working 5 months ago (its so hard to find a job these days) and have been saving up - Before that i had the unpleasent experience to use a compaq that had a replaced hand-me-down graphics card - outside of that it was $984 base price and little over $1000 with tax.
Reply to KhaoticOne
I'll take a wild guess and say is it this one?
http://tv.rca.com/en-US/ModelDetai [...] ogy&PC=LCD
It has a 1366 x 768 resolution. Shouldn't need a big card to run that.
Reply to nobly
that is the tv, and your extra research on the native rez is very appreciated.
Reply to KhaoticOne
There are 1100 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
