I have two win2k member servers in the same GPO in the same active directory
domain. I have a Win XP client that connects to a VPN server and maps
drives using a login script to both of these servers. When I login to the
laptop, not the domain it works fine with
one server but with the other server I get the error below. When I login to
the domain I don't get any errors and everything works fine. I don't
understand why there would be any difference in connecting to these servers
with a single username and password since they are in the same domain and
even GPO?
"The password is invalid for \\servername\sharename.
Enter the username for 'servername'
Enter the password for 'servername'
I enter the information and get a quick login script error related to a bad
username or password.
After that the login script continues without a problem and maps the
remainder of the drives to the other server.
My login script is only:
net use m: \\servername1\sharename (results in an error)
net use n: \\servername2\sharename (works fine)
net use n: \\servername2\myshare (works fine)
