ok so i have been studying differant kinds of cooling for ablout 3 months and desided on watercooling to start out with. i gathered all my parts, tubing rad coolant block pump, and assembled. upon startup none of my peripherials worked (mouse keyboard monitor). so i diagnos it as a fried mobo and get a new one. once again assemble and the same problem occurs. so i diagnos that the 1/2" lines are pulling at a wierd angle on the cpu. so i change to 3/8" tubing and the same problem. so at this point im maddly swapping parts. you name it i swapped it. but when i would put the stock cooling on instead of the water block it would work. so now im franticly calling techs all over the country about this problem and only one told me that i should try to keep the fan plugged in while i have the block on. i have yet to try this, my plan is to try it on tuesday. in the mean time could i get any tech help from you guys? my rig is custom built by me and i love it like it is my child (its my first) and i would really like to fix this issue.
these are my specs right now minus the water cooling. i havent updated the pictures.
PLEASE HELP!
PLEASE HELP!
