I recently bought a WD320 to suppliment my WD120 hard drive. I've physically installed the new drive and the computer sees it - sort of. It won't let me actually access it even tho it says it's there.
I'm running on a Gigabyte GA-7N400 mobo and I'm running Win2k. I've got the old hard drive on the end plug of the ribbon cable and the new drive on the middle plug. I've tried it with the new drive's jumper set to auto detect, and I've tried it with the jumper manually set to Slave. When I enter the Bios, the computer sees both drives - WDC WD120BB-00CAA1 and WDC WD3200JB-22KFA0. When I go to add/remove hardware and try to trouble shoot a device it also shows both drives, and says both drives are working properly.
Despite that, my C: drive only shows 111 GB total capacity, and there is no other Hard Drive listed at all. Can someone help me figure out what I've done wrong here? I've tried unplugging the old drive completely and just plugging in the new drive to see if it works. I get an error message basically saying there's no OS, so I assume that means the drive is good.
I would really appreciate any help anyone could give me on this.
-Dwarf
-Dwarf
