Help... PSU/MOBO question
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Help... PSU/MOBO question
I have a Dell 8250 with its original PSU at 250W and its original motherboard. If i upgrade the PSU to a 350W will that create any problems such as overpowering the motherboard or anything of that nature? I talked to a dell representative via chatroom and he said, I cannot b/c the motherboard will not handle it. Is this true? or can i indeed upgrade to the 350W and not do any damage to the system?
Sponsored Links
You can upgrade but you will need an adapter. There is another thread floating around here somewheres with a link....
Reply to FlyGuy
I have a system that is almost identical to yours.
Dell 8250
P4 @ 2.4Ghz
768 Mb Pc 1066
I had a enermax noisetaker 470w psu, that I purchased for a build that never hapened. To make a long story short, this psu is now in my 8250. No adapters needed.
The one thing that you will have to consider is that, there is not a hole in the back of your dell case for the power switch on an atx psu. But a dremel will fix that.
Someone pointed out on the other thread that Pc power and cooling makes psus that are compatible with dell systems. That may be your best option.
But I have to call BS on the statement that the MB won't handle a bigger psu.
Reply to Racktracker
Your components will be fine.
Each component 'draws' power from the PSU, so for example your CPU will draw 75W from the PSU. So for a 250W PSU, you'll have 175W available for other components. It doesn't matter how much wattage your PSU has, as long as it can handle the power that all the components 'draw'.
The only thing I can think of is that the new PSU might not fit where the old PSU is. (Proprietary Dell case, what else?)
So you'll probably want to do some measuring before you go and buy a new one. Otherwise you might have to modify your case.
Reply to nobly
Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Help... PSU/MOBO question
There are 1109 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
