Tom's Hardware > Forum > CPU & Components > CPUs > Help on AMD 64 3000+ specs
Forum CPU & Components : CPUs - Help on AMD 64 3000+ specs
Hi I just got an AMD 64 3000+ 2.0Ghz cpu for the ASUS k8v-x mobo, with the idea that i'd have a 3.0Ghz PC, was I wrong ?? :oops:
Sponsored Links
Quote :
AMD's processors are slower on frequency. Everyone thinks that the higher the frequency the better the processor, so in AMD's mind it's giving you a number that's comparable to Intel. In other words, AMD's AMD64 3000+ is comparable to an Intel P4 that runs at 3.0Ghz - but it only runs at 1.8Ghz stock.
Reply to doublehelix
So i don't have to be alarmed when i make a cpu speed check and get a result of 2.0Ghz ?
Reply to Maximus86
You were only wrong in the sense that you thought you'd have a "3 GHz PC", but, it wil perform about the same as if it were a fine running Pentium 4 3 Ghz processor, which is not a bad thing.
The Athlon 64 series are fine cpus!
Reply to mdd1963
Thanks you all for your fast reply !!!!! :D
Reply to Maximus86
There are 1202 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
