Faulty power or what?
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Faulty power or what?
Rig:
AMD 4800+ Dual Core
2 gig Corsair TWINX-3500LLPRO
A8N32-SLI mobo
1 DVD reader, 1 DVD reader/writer
1 Floppy
2 BFG 7800GTX 512 OC using SLI
1 10k WD SATA 74GB
PSU: BFG 600W (2) 12V rails with 20A on each rail. SLI certified from slizone.com
I am trying to run a benchmark with 3DMark06 and my machine is locking up on the last phase of the test doing HDR/SM3.0 It sounds like my power supply fan is really huffing, RPMs on fan are high and warmer air than usual is blowing out from the PSU. Do I need more juice for this rig?? Should I return this PSU? If so, what would you recommend for replacement based on hardware above? I am using a 120mm intake fan and 120mm exhaust.
Sponsored Links
http://extreme.outervision.com/index.jsp
go here and put in exact info for you machine with what you've listed for 100% peak utilization you need a minimum 484 watts so even with anything extra you may have you probably would'nt need more than a 600 w
it sounds like an overheating problem to me your ps has Noise Killer Technology During regular operation, the fan slows down to reduce unnecessary noise. which sound to like the ps fan is temp controlled. so as you run 3dmark 06 at the end of the test you cards are overheating and your ps fan is spinning faster because of the increase in temp. you can check this by opening display properties ->settings->advanced-> your card-> and temp setting. run the 3d mark tests except the last one (the one you lock up on)and check the temps. 2 120 mm fans should do well depending on your case. you can also try removing the side of case for better cooling to see if cools any better.
what case do you have?
Reply to Wgfalcon
Thank you for the response :)
Here is the link to the case I got, its lightweight aluminum and looked good for air flow..
http://www.tigerdirect.com/applica [...] u=ULT31824
I'll try that link out.. thanks agina for the input..
Reply to gibreaper
nice case looks to have good airflow and plenty of room
Reply to Wgfalcon
I removed the side and am using a room fam directly on the lower part of the mobo, and the temps have dropped 8C on one card and 10C on the other.. This case may need more airflow that 2x120mm fans for this SLI setup. I am going to run the benchmark again to see if it lives or burns..
Reply to gibreaper
Well, well that done the trick.. got my first benckmark (8079 with nothing overclocked) so it seems I have poor air flow. Before I was testing and my cards were getting to about 68C, now after running that benchmark (which I have never completed due to freeze/reboot) now is only 50C. A great improvement. The concern I have now is there is nowhere else to mount a fan blowing directly onto those BFG cards.. It amazes me to think of 4 card SLI.. cooling alone stifles me.
Reply to gibreaper
Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Faulty power or what?
There are 871 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
