Okay I have a new 250GB Seagate and want it as the primary boot drive. Right now I have a 160GB Maxtor as the boot drive. After I write 0's to the Seagate, I put in my restore CD that includes some drivers and WinXP Home. After installation, copying files, etc., it restarts. I see the Windows XP logo with the progress bar sliding to the right, THEN BAM! Screen goes blank and I see nothing and nothing happens afterwards. I checked the jumpers, tried different IDE cables. Also I tried writing 0's to the Seagate, then loading it as a slave drive to my Maxtor drive, then copying all files, etc. to it. Then I try to load the Seagate again as the primary master drive and adjusted the jumpers, disconnected the Maxtor, and the same thing happens. I called Seagate 3 times but nothing has worked so far. One of them suggested I get the retail WinXP but I really don't want to have to. My PC manufacturer is long gone so no support from them. I don't know what to do now but look elsewhere for help.
Is there a way to make a Windows XP installation disc from my restore CD or off my Maxtor drive? Any other possible solutions? Anyone else who's had this problem before? Thanks, and I really appreciate everyone's help.'
edit: I don't think it's a problem with recognizing storage over 137GB, it shows in BIOS as 250GB. I also believe my motherboard is proprietary. Rest of the system includes a P4 2.8GHz w/o HT, 9800 pro, sound blaster live, dvd-rom, dvd+rw, and floppy drive. The system is a little over 3 years old. Thanks again.
