Tom's Hardware > Forum > CPU & Components > CPUs > Help overclocking AMD Barton 2800+
Forum CPU & Components : CPUs - Help overclocking AMD Barton 2800+
System
AMD Barton Athlon XP 2800+
Gigabyte cooler for CPU
Abit AN7
2X512 Corsair DDR400
I try to overclock and to obtain from FSB 166x12,5 to FSB 180x11,5 with memory timings default and it becomes very unstable,after that i raise the Vcore to 1.73(step by step) and memory Voltage, the same (memory errors or buting problems)
should i raise de Voltage to Northbridge to?
I want to reach a higher FSB without lowering the memory frequency and stable.
Which settings ar better to have
FSB 170x12 and the memory at frequency 333 with 2.2.2.6(actual)
or
FSB 180or200 x10/11 and the memory frequency 400 and 2,5.4.4.8 or higher timings
Sponsored Links
I don't have any advice, but when I tried overclocking my Barton 2800+ I killed two MSI motherboards. I'll never buy MSI again.
Reply to TechnologyCoordinator
- 0 +
I believe that processor is multiplier-locked. The only way to O'C it is to raise the FSB. :?
Reply to 9-inch
why don't you use the old famous athlon xp multiplier unlocking method?
it will require some physical touch job on cpu;
but i think it will be worth it...
barton was super famous for that method...
you can even make your cpu to amd mp...
Reply to alphakp295
First drop your memory timings way down cas 3. Set a divider too 2:1 (or something very low), so that your ram isn't limiting your OC. See how high you can get the FSB. Watch your temps. Take note.
Then go back to a 1:1 divider with a stock FSB and tight timings. Raise the FSB slowly untill it gets unstable. Take note.
Now you should have your chip's (or your MoBo's) highest speed and your rams limits.
Play with settings in between. Depending on what you are doing, folding or playing games, you may end up happier with a 200 fsb a 5:4 memory divider and cas3.
Reply to Cunninglinguist
Quote :
Not all of them. I was lucky enough to get a barton that was unlocked.
The XP-Ms were all unlocked. They fit standard socket A, low stock vCore and great OC's. You can still find them on eBay.
My multiplier is unlocked without other(physical) modification.
Higher FSB comes with memory problems if they are set at DDR400.
Maybe the voltage for memory(2.80) and CPU(1.73) cause the problems,or the bad timings?
It is a sensitive equilibrium between CPU and RAM
Ex: when i have FSB 180 is not entering windows
Reply to dragosgorjan
If it's unlocked and your board supports it, drop your multiplier and run at 200 FSB.
Try 200 x 9.5 to start.
I put the FSB to 200 x 10 and succes,no errors with default timings 2,5.3.3.8 (with 9.5 is not working at all)
I will test it in this config and after that i will raise to 11/12.
Quote :
I guess I was lucky too! I bought the slowest Barton for ~$75.00 I rasied the clock to 200-202MHz w/ 10.5 multiplier and I'm running ~2100MHz . My memory is at 333MHz 2-3-3-7 on an Abit A7N.
So not all Barton's are unlocked? What's the deal with that?
-AM
Reply to atticman
I would try
10 x 205
10 x 210 etc
before jumping into another multiplier, but hey it's your machine.
There are 1393 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
