Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Thermaltake Armor Case: Post your reviews!
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Thermaltake Armor Case: Post your reviews!
Hey guys, i have ordered a Thermaltake Armor case (Aluminium) to use for my new gaming system (lets say high-end) cause i've heard so much good things about it, for example its exc. airflow and cooling abilities etc. I just wanna be absoluteley sure that this case is gonna be a good experience for me so if you own one plz tell me your experience with it, and is it as good as its reviews?
Sponsored Links
ive ordered this and am in the middle of building my comp(just waiting for my copy of windws to be delivered). i have of course been installing hardware and can say that it is very simple. the two hard drive cages are a breeze to remove including the one with the fan. installing dvd drives and the like is simple even with the motherboard installed.
i have a a8r-mvp mobo from asus and did find it slightly difficult to connect the front fans mobo connector but as long as you keep your cables tidy it shouldn't be a problem.
it also feels fairly solid and the interior is not flimsy. the only problem is that if you want to install a dual slot gfx card you will have to remove the tooless pci device. i personally prefer screws so not too much trouble for me. i will be testing airflow and waether i feel the need for the fan at the top when or if i get my comp up and running
Reply to strangestranger
There are 571 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
