Hello all,
Recently I've tried turning my two standard Seagate 7200.7 120GB 8MB IDE hard disks into a RAID 0 array from which I can boot Windows. This is the first time I've tried to create such an array.
As far as i know I've followed all of the instructions in my motherboard manual, which is a Gigabyte 7VAXP-A Ultra board with a Promise 20276 RAID Chipset.
Now I've managed to configure the Promise RAID to use the two Seagates as a RAID 0 array, which it assures me is functional. Addtionally I have used FDISK to clear both disks and create a primary DOS partition of approx. 240GB.
However when I boot from the WinXP Pro SP2 CD it gives me the message "Setup is examining your hardware configuration". Alas, my computer does nothing further and does not load the Windows setup screen, nor give me the chance to press F6 and install the Promise driver, which I have on floppy.
This is driving me wild as all troubleshooting and forum articles I've seen cover the initial setup of the RAID array, or installing the RAID driver once the Windows setup screen has loaded. I'm stuck right in the middle. Stumped.
Also when I revert back to a single drive, non-RAID configuration the Windows setup screen loads normally... Is there a chance that I may have a bad copy of Windows or is this an incompatibility issue?
Any help on this would be much appreciated.
Cheers and take care.
