I'm considering painting some of the internal components, and I had a couple questions...
1. Is there a type of paint you'd recommend for cables? Something flexible?
2. Aside from likely voiding the warranties, is there any reason with proper masking to avoid painting DVD and floppy drives (the drive body itself, not the bezel).
3. Has anyone tried using a non-conductive paint directly on circuit boards and/or electronic components?
