I have a 3.5" extenal USB SATA enclosure (bytecc).
First it worked great, then had intermittent problems, now its broke.
I took it apart, tested the power connectors ect, power is fine.
I replace the short IDE cable with a long rounded cable I had handy and now it works great again.
There is zero clearance top and bottom and the 2 inch cable needed to be folded to get the enclosure shut.
I am using a 6" carefully folded and there is a 3/8 inch gap keeping me from closing the unit. Duct tape is holding it together now.
I found an old mobile rack, but only one in is regular IDE the other has the wrong pin config an is soldered to the board
If anyone knows where I can get a 2-3" IDE cable (fairly cheap its to fix a $34 product) let me know.
