Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Audio Compression Problem
Forum Windows XP : Windows XP General Discussion - Audio Compression Problem
Archived from groups: microsoft.public.windowsxp.basics (More info?)
I'm having audio problems on my XP Home
To troubleshoot, I went into Control Panel | Sounds and Audio Devices |
Sounds Tab
When I try to play any of the Sounds, I get the following message:
"Error: Windows cannot play the <path and file> file. The file may be
damaged or may use an unrecognized compression format. To resolve this
problem, replace the file or use Add/Remove Programs in Control panel to
install Audio Compression."
In the Hardware tab, it lists Microsoft Audio Compression Manager.
Under Codecs, I have:
IMA ADPCM Audio CODEC
Microsoft ADPM Audio CODEC
Microsoft CCITT G.711 Audio CODEC
Microsoft GSM 6.10 Audio CODEC
msg723.acm
Windows Media Audio
Indeo audio software
Fraunhofer IIS MPEG Layer-3 Codec
Sipro Lab Telecom Audio Codec
Microsoft PCM Converter
Any ideas of what is missing?
Thanks,
Martin Schmid, EIT, CCSA, MCDBA, MCSE
Sponsored Links
Try reinstalling the sound chip or card drivers
> Sounds Tab
> msg723.acm
> Windows Media Audio
> Thanks,
Reply to Anonymous
Tried that to no avail.
Thanks,
"Rho_1r" <Rho_1r@hotmail.com> wrote in message
news:5AA353D2-63C7-4484-BC40-A6AAAFB42BE6@microsoft.com...
>> Sounds Tab
>> msg723.acm
>> Windows Media Audio
>> Thanks,
Reply to Anonymous
There are 1183 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
