Archived from groups: comp.dcom.vpn (More info?)
Here is the setup:
Win2K PPTP Client------RH 8.0--------INTERNET------RH 8.0 PPTP Server
Cuz my RedHat 8.0 uses 2.4 kernel and only one PPTP client in the
network
As stated in
http://www.impsec.org/linux/masque [...] q_vpn.html
I don't need to patch the kernel.
I just need to add the normal masquerading rules.
/sbin/modprobe iptable_nat
/usr/local/sbin/iptables -t nat -A POSTROUTING -o ppp0 -j MASQUERADE
echo 1 > /proc/sys/net/ipv4/ip_forward
However, Win2K PPTP Client can't establish VPN connection successfully.
The negotiation stops just after the authentication.
Below is the error message in RH 8.0 PPTP Server:
GRE: read(fd=6,buffer=8055600,len=8260) from network failed: status =
-1 error = Protocol not available
CTRL: GRE-tunnel has collapsed (GRE read or PTY write failed
(gre,pty)=(6,5))
CTRL: Client 219.133.238.250 control connection finished
But if Win2K PPTP Client connects to Internet directly (not thru
firewall),
the VPN connection can be established!! (using the same setting)
Why???
Sponsored Links
bolero92@yahoo.com wrote:
> Here is the setup:
> network
> As stated in
> (gre,pty)=(6,5))
> firewall),
> Why???
GRE is a separate protocol from TCP. Your NAT is obviously not
forwarding this protocol to the client inside your network.
Note: GRE does not use "ports" so you cannot forward a port to make this
work. Your NAT device either supports GRE or it doesn't. If it doesn't
then you are screwed. Even cheap $50 routers can usually forward this
protocol.
WARNING! Email address has been altered for spam resistance.
Please remove the -deletethispart-. section before replying directly.
Mike Drechsler (mike-newsgroup@-deletethispart-.upcraft.com)
Reply to Anonymous
Tom's Hardware > Forum > General Networking > VPN, VoIP, Video Conferencing, Remote Connections > VPN Masquerading problems
There are 691 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 demondrumer won the Freshman badge
  • 01:00 tehue won the Freshman badge
  • 12:11 mi1ez won the Watchman badge
  • 01:00 sighQ2 won the Freshman badge
  • 09:06 ulysses35 won the CPUs badge
  • 01:00 fleeb won the Freshman badge
  • 01:00 jaymoney61 won the Freshman badge
  • 07:06 amdfangirl won the Watchman badge
  • 01:00 benw won the Freshman badge
  • 01:00 anmjoven won the Freshman badge
