What is the problem cannot partition hard drive due to large number of partition
Hello,i recently installed windows 7.. it had only 2 drives c: and d: .. i need to partition d: drive into 3 partitions. is it possible?
4 answers Last reply
More about what problem partition hard drive large number partition
  1. have you tried the Disk Manager?
    It will allow you to resize your current partition
  2. http://www.partition-tool.com/personal.htm
    this will do it an for free!
  3. have you tried the Disk Manager?
    It will allow you to resize your current partition[/quotemsg
    thnks, i tried tht but d problem is its giving d error too many partitions ? i already have a c, d n e drive with ubuntu installed along with windows 7..
  4. Hi,
    You could use the Disk Management to shrink your partition D to get some unalloacted space then create the new partition on it.
    Note: because you have three primary partition already ( C drive,D drive and an hidden drive "system reseverd" which is contain the boot file of the Windows 7) , when you create the fourth partition the partition will be default as "extended partition" therefore you could only create logical partition by shrink this "extended partition" if you shrink the primary partition you can not create any partition. This is because the system could only allow 4 partitions, three primary partition with one Extend partition
    You could choose other partition software to help you create partition which has the option to choice "primary partition" or "logical partition"
    you could learn how to create partition from
    http://www.partition-magic.org/help/create-partition.html
Configuration Windows 7 Partition Hard Drives
