Yes you can have 2x128 and 2x256, but they have to be in the right slots, as you stated. Unless you have 1066, then I think you don't need to put them in as pairs anymore.can you mix different size modules in pairs...123 in slot 1 & 3...256 in slot 2 & 4?
can you mix different speeds as above...800 and 1066?
is there an alternative that will operate in place of rambus?
can you mix ecc and non-ecc?
Thank you!
