Ok. Putting together a computer system and would like any constructive input as to what I have so far. Machine will be used for gaming as well as work related (Word, Excel, possibly circuit simulations, etc).
Was trying to keep it under $2k. I already have a monitor and speakers I plan to use with the new system. I included some heatsinking that may not be necessary (unless I try to oc the cpu or memory). Plan to run two 10k rpm Raptors in a Raid 0.
Feel free to point out any components you feel should be changed, or just general observations, etc that might be helpful in finalizing the system before I purchase and build it. Anyway, here it is:
Case
COOLER MASTER Wave Master TAC-T01-E1C Silver All Aluminum Alloy ATX Mid Tower Case without Power Supply [ Link ]
Power Supply
Antec TRUEPOWERII TPII-550 ATX12V 550W Power Supply [ Link ]
Motherboard
ASUS P5N32-SLI Deluxe Socket T (LGA 775) NVIDIA nForce4 SLI ATX Intel Motherboard [ Link ]
Processor
Intel Pentium D 830 Smithfield 800MHz FSB 2 x 1MB L2 Cache LGA 775 Dual Core, EM64T Processor [ Link ]
Processor Cooling
THERMALRIGHT SI-120 High Performance Heatsink [ Link ]
THERMALRIGHT LGA775 RM Retention Bracket for Socket 478 Coolers [ Link ]
Antec 75003 120mm Ball Case Cooling Fan [ Link ]
Memory
CORSAIR ValueSelect 2GB (2 x 1GB) 240-Pin DDR2 SDRAM Unbuffered DDR2 667 (PC2 5300) System Memory [ Link ]
Memory Cooling
x2 VANTEC ICEBERG DDR-A1C Copper RAM Heat Spreader [ Link ]
Video Card
eVGA 256-P2-N515-AX Geforce 7800GT 256MB 256-bit GDDR3 VIVO PCI Express x16 Video Card [ Link ]
Hard Disk
x2, Raid 0 Western Digital Raptor WD740GD 74GB 10,000 RPM 8MB Cache Serial ATA150 Hard Drive [ Link ]
Did not included the DVD, Floppy, Mouse, or KB here. Here is the link to the complete NewEgg wish list if you wish to see those: [ Wish List ]
Case
Power Supply
Motherboard
Processor
Processor Cooling
Memory
Memory Cooling
Video Card
Hard Disk
