I posted this in the gigabyte forums but I've had no answers there so I thought I'd try here incase it's because it'd get missed in there due to low traffic. Mods, please delete the other thread if this goes agains the TOC.
Ok I bought a GA-8S655FX-L (Rev1.0) and stuck in Kingston 1GB DDR PC3200 400MHz Non-ECC CL3 (3-3-3) 184pin DIMM's (Kit of 2 x 512mb) which has been running fine for nearly a year.
I then decided to upgrade as I need alot more ram, so I bought 2 x Kingston 1GB 400MHz DDR PC3200 DIMM 3-3-3 ok, exactly the same memory apart from the size which I did because I figured that will be the least painfull upgrade.. right?? How wrong was I! :lol:
Anyway, The setup was, I had the two 512mb dimms in slot 1 of channel a and b with the two 1gb dimms is slot 2 of channel a and b. thus using the DDR correctly and getting the best performance out of my dimms.
Anyway, I had lots of errors and random crashes so I knew something was wrong. I then ran memtestx86 and it came up with lots of errors on test 5 (I think that's where it does a block copy between the modules).
So I then tried to insert the dimms in different configs. The upshot of that is I can have the dimms in any combination (2x512, 1x512+1x1gb, 2x512+1x1gb, 2x512 on one channell and 2x1gb on one channel) etc but if I use the correct config, i.e 2x512 across 2 channels and 2x1mb accross 2 channels, I get the errors. Thus I think the issue is when the mobo tries to use DDR with two sets of modules, it errors.
I've been running with the 1gb dimms fine for nearly a month now so they aren't faulty. I've installed the latest mobo firmware (F) and I've installed the latest drivers fwiw (since memtest works on the bios level it shouldn't affect the OS). I've also tried gigabyte support but the best suggestion I've had from them is not to use different memory sizes
I am right in thinking that you can mix DDR memory as long as they are on seperate channels and the same slot?
Any help would be appreciated Thanks 8)
