Wierd TFT display problem
Hey all. Just got my DVI cable last night and hooked it up to my Cornea 17" TFT. DVI is nice! One problem though, every now and then, the screen will split in two, with about 1/4 of the bottom of the display showing what is at the top. ANy ideas or suggestions. I have a PNY GeForce 3 Ti 200 and have tried it in many different resolutions, and have not solved it. HELP!
1 answer Last reply
More about wierd display problem
  1. I've seen that happen when the LCD doesn't "like" the signal sent. Happens in analog on my TFT7020 (the broken one though) on my 200Mhz PC w/ Cirrus Logic.
    Only if you let me see the Umpa Lumpa- Homer Simpson.
Flat Panel Monitors DVI Peripherals Displays
