Disclaimer: I do not claim to be a hardware person, by a long shot
I have some questions.
quite a long while ago, my system died. After much fiddling I decided that it was a graphics card problem, as my radeon 9800pro 256's fan was totally missing and upon further inspection I noticed that the center post to its heatsink had basically melted in half.
I talked to the guy at the local computer store about a new graphics card and mentioned the problem I had with the last one. He supposed if the card's temperature got high enough to actually melt plastic it just *might* be a mobo problem.
So, hoping for the best, I ordered a slightly downgraded copy [i'm on a budget] of the card I had before, and tried it with no luck.
When I disconnect everything from the motherboard but the cpu/heatsink/fan and power it on, it gives me a long beep/pause that repeats indefinitely.
I've decided to try to find another motherboard to give that a shot, but I don't even know for sure if that was problem.
Here are the specs:
MSI 6570-020 nforce2
athlon 2500+ socket 462 processor
[model number axda2500dkv40]
a raidmax 350w max power supply
2 sticks of 512mb ddr ram
a radeon 9800pro 128mb...an ethernet card, a couple of hard disks, a pci soundcard, and all that stuff.
Is more likely that the motherboard died, the processor died, or both? Would there be any easy way to find out? On that note, I have $200-$300 to spend on a new motherboard and/or processor. Does anyone have any advice on whether I should try to salvage what I have and go up for another motherboard? Or should I migrate to 64-bit? If so, is it possible to find a reasonably good processor/mobo pair in this price range?
I'm not really much of a gamer at this point in my life. The only games I really have been playing are Gunz International [good job team...] and Sid Meier's Alpha Centauri. I play mp3s with winamp and run Acid 4.0.
Any help would be much appreciated.
Here are the specs:
