OK, I'm building a system. I need to know if these components would be fine with stock cooling and only a few other fans. I want to buy a water cooling system, but I don't have the cash right now and want to wait a couple months. So, my system would be running for a while without much to cool it.
As long as you don't button it all up in a case with no ventillation, it'll be fine on stock cooling. Why do you think you'd have a problem? Overclocking?
It's cool to run with stock cooling as long as you have good ventilation and air circulation inside your case. Also keep the overclocking on the minimum like below 10% with the stock hsf. With all that it should run fine and cool till you get that water cooling system.
