Hey all,
Here is my situation. We currently have 80 ACER Veriton 5700GX's here in 4 PC Labs. Each machine has a removable caddy bay for teaching purposes. Nearly every student is issued with a caddy. This is the first year we have been given these PC's last 3 years we were issued with 80 HP Vectra's which worked with caddy no problems.
Here is the current hard disk setup.
Channel 0 Master: IDE Caddy
Channel 0 Slave: DVD-Rom
Channel 1 Master: 80GB SATA HDD
Channel 1 Slave: NONE
Now, the way we wish for this to work, is when a student puts a caddy in the caddy bay we wish for the caddy hard disk to boot over the SATA hard disk. Obviously meaning that the IDE Caddy has a higher boot priority than the SATA. We have our BIOS's locked as we have a wide range of students at all different levels of knowledge. Which of course can be quiet damaging in a teaching environment.
Here is the problem. I can place a caddy in the first time, boots perfectly fine, no dramas. I can also remove the caddy and put 3 or more caddys in with different hard disks. Still not a problem, BUT the problem occurs when i place a caddy in, boot it, turn the machine off and remove the caddy then put another caddy (with the same model hard disk) or the same caddy back in the machine. After doing this you boot the machine up and it puts the SATA HDD as a higher priority than the IDE Caddy. This now means we have to manually change the boot order for the student, and this only works the once. Each time a student puts a caddy back in the machine it continues to place the SATA drive as the first bootable drive.
Has anyone got any idea's or maybe solutions? Or even had similar problems in the past? The only solutions i can think of is the following:
Changing the Serial ATA disk's all to IDE (Not exactly a cheap option).
Getting a Serial ATA Converter for the IDE Caddy's to convert the caddy to a Serial ATA connection (Allthough im not too sure this will fix it).
Replace all the IDE caddy's with Serial ATA Caddys (Again not a cheap option and may not work)
Replace all the IDE Caddy's with USB Caddy's (And of course once again no idea if this will work either)
Most of those solutions still come back to the fact that you need a Boot Order. And it seems that no matter how many times you save the boot order int he BIOS it will continue to reset as soon as the caddy is removed.
Any help on this matter would be greatly apreciated.
Regards.
Regards.
