Archived from groups: comp.dcom.vpn (More info?)
My laptop establishes a VPN tunnel using Prosafe VPN05L client software
connecting with a Netgear FVS318 at the office. I then connect my laptop to
my office machine using Remote Desktop. Both the VPN and the Remote Desktop
work beautifully....until I go to my buddy's house and try the same thing.
At his house the VPN connects just fine, but the remote desktop won't
connect. I cannot ping any hosts on the remote LAN either. Whereas I could
ping remote hosts from my residence. My buddy uses a different ISP. So what
could an ISP do to allow a VPN connection, but block a Remote Desktop
session? The ISP is what I suspect as the problem because both the VPN and
the RD work fine at my residence under my ISP.
Can someone give me an idea of what might be preventing a remote desktop
session in this case?
Thanks,
-James
Sponsored Links
are you suing a router? could that be blocking ports? - also double check
with the ISP and see if they block any ports
"James" <anonymous> wrote in message
news:HridnVxu17_tfrrfRVn-2A@bright.net...
> to my office machine using Remote Desktop. Both the VPN and the Remote
> Desktop work beautifully....until I go to my buddy's house and try the
> same thing. At his house the VPN connects just fine, but the remote
> desktop won't connect. I cannot ping any hosts on the remote LAN either.
> Whereas I could ping remote hosts from my residence. My buddy uses a
> different ISP. So what could an ISP do to allow a VPN connection, but
> block a Remote Desktop session? The ISP is what I suspect as the problem
> because both the VPN and the RD work fine at my residence under my ISP.
> Thanks,
> -James
Reply to Anonymous
Does you buddy have a router? Does it support PPTP or IPSEC passthru? If
you buddy has a Cable or DSL modem that is separate from the router, try
connecting your laptop directly to the modem, and see if you still have the
problem. That would identify if the problem is caused by the ISP or the
router.
Mike Schumann
> Thanks,
> -James
Reply to Anonymous
- 0 +
"Mike Schumann" <mike-nospam@traditions-nospam.com> wrote in message:
> the problem. That would identify if the problem is caused by the ISP or
> the router.
Thanks Mike. However, I found the problem. It was his subnet (192.168.X.10).
Turned out to be the same as the remote secure group subnet.
James
Reply to James
Tom's Hardware > Forum > General Networking > VPN, VoIP, Video Conferencing, Remote Connections > Remote Desktop over VPN problem
There are 1210 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
