Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > WTF? Need Help! Did my PS burn out? Too many fans?
Forum Homebuilt Systems : General Homebuilt - WTF? Need Help! Did my PS burn out? Too many fans?
Ok, so I just put together this system. Installed windows, graphics, sound card. Tried to install F.E.A.R. but the thing shut off entirely half way through it. Now when I try to power on I just get a momentary high-pitched "squeak pop" sort of noise. Nothing else.
This is the system:
Athlon 64 3700+
Biostar TForce4 SLI 939
EVGA 7800 GT CO
Sound Blaster Audigy 2ZS Platinum Pro
Seagate Barracuda 300MB SATA
A SAmsung and a Hitachi ODDs
and a Mitsumi floppy
AND 6 (six) 80mm fans
also an Enermax Liberty 500 watt power supply
Sponsored Links
Sounds to me like the PSU is not plugged in good enough. Check the connections at the back of the PSU and make sure the connections on the board are solid.
At least that's what it sounds like to me.
Reply to Luminaris
- 0 +
That wasn't the problem. The power supply makes a wierd noise when the power button is pressed. Nothing turns on.
Reply to sobjw
you leave that running for a while and you should here a bang, think you need a new psu
Reply to fluxpunk
There are 1248 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 Foxer57 won the Uniformed badge
  • 01:00 gregmo won the Freshman badge
  • 01:00 vishnuvamp won the Freshman badge
  • 01:00 whiz won the Freshman badge
  • 01:00 jconline won the Uniformed badge
  • 01:00 qiaoda won the Uniformed badge
  • 01:00 sykohedd won the Uniformed badge
  • 01:00 jundja won the Uniformed badge
  • 01:00 cnsftci won the Uniformed badge
  • 01:00 VistaVendetta won the Uniformed badge
