Help building fast pc
Forum Homebuilt Systems : General Homebuilt - Help building fast pc
Hi Everyone,
I am in the market to build myself a new computer. It needs to be blazing fast for rendering and graphics etc. I need some help on case selection and any other suggestions from the gurus out there. Price is no matter, speed is paramount. Here is what I have thought about putting together so far. Any help is appreciated. Also, when its built I will run some tests if you users want to see some benchmarks on a quad opteron system. Thanks.
MOBO: Tyan Thunder K8QW (S4881)
PROC: Four Opteron 885 2.6Ghz
MEM: 16 Gigs of OCZ EB DDR PC-4000 Platinum
STORAGE: I will have two RAID-0 Array's. One with two 147GB Seagate 15K U320 FibreChannel Drives and one with
four 300GB Seagate 10K U320 FibreChannel drives. I want to mount the drives as hot swapable using kits from CI Design (http://www.cidesign.com/product_detail.jsp?productID=42)
Controller Card: What is the best for my application, Qlogic or Emulex?
VIDEO: SLI Nvidia Quadro fx 4500
CASE: need a good suggestion with size and plenty of space. I also plan on using 5.25" HD kits to setup my 5 Drives in the front bays.
Sponsored Links
I nearly fainted when I saw the parts listed and then thought about the price tags =/
Go with a TJ07 case, they look so dead sexy. Just thinkin about one... damn... AFK
Reply to Maxiius
why don't you go with the fujitsu mau 147 15k drive
http://www.storagereview.com/php/b [...] h_sort.php
Reply to slamattoms
- 0 +
Thanks Slamattoms. It certainly looks like the better drive. I will use those for the 147GB Drives.
Reply to jribbe1
- 0 +
8O
All I can say is....WOW. Ummm.....I'm gonna sit this one out.
Reply to bweir
- 0 +
Any thoughts on a RAID Card?
Reply to jribbe1
Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > Help building fast pc
There are 1099 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 vianescute won the Freshman badge
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
