can i use a 24pin PSU on a 20pin motherboard?
Last response: in Components
- Can I use a 20pin MB connector PSU with a 24pin MB? - Forum
- Can I use a 20-pin PSU in a 24-pin board? - Forum
- 24-pin ATX Power on mobo using 20-pin plug from PSU - Forum
- 20pin PSU on 24pin motherboard? - Forum
- 20-pin powersupply in 24-pin motherboard - Forum
- should i plug 24pin or 20pin into motherboard? Forum
- can i use a 20pin power supply in a 24pin slot? Forum
- MotherBoard Doesnt Contain 24pin or 20pin Connectors!?! (HELP) Forum
- Can I use a 20+4 pin PSU with a 20-pin motherboard? Forum
- 24pin mainboard use 20pin power Forum
- 24pin power supply into 20pin motherboard Forum
- PSU 20-pin into a 24-pin ATX Mobo Forum
- 24-pin PSU down to 20-pin MOBO? Forum
- ok to connect 20-pin PSU to 24-pin MoBo? Forum
- PSU 20-pin or 24-pin?? Forum
- 20-Pin PSU vs 24-pin Mobo Hookup? Forum
- Plugging 20-pin PSU into 24-pin Mobo Forum
- 24-Pin PSUs on 20-Pin Motherboards ?? Forum
- Solved24-pin PSU connector absolutely will not latch/connect into the motherboard Forum
- 24pin PSU compatible with 20 pin motherboard input? Forum
- More resources
Read discussions in other Components categories
