I am possibly being very stupid, but I am starting to put my stuff together and so thought I would start with something easy, installing the DVD Drive in the top 5.25 bay.
I have attached the drive rails to my Pioneer 111D, and assume I insert the drive from the front of the case, but the rails only go back so far and the drive sticks out.
I cannot move them further back on the DVD drive as the drive does not have any more screw holes.
I thought I could be putting it in the wrong way around, but there seems to be no way I can get the drive fitted by inserting it from inside the case, unless of course I am missing something.
I think I have managed to fit the rails correctly by moving them towards the front of the DVD, so it would fit OK, but now I just cannot insert the drive into the case from the front or from inside the case.
