I am looking to spend the least amount of money possible for the best gaming system possible. PLEASE PLEASE PLEASE comment on anything any of you see that should be switched out or modified. I am picking out things to my liking, but if they are not worth the money, or if there is better for around the price that the item is listed at, then please let me know. THANKS!
If there's anyway to reduce the price and get a lesser item with nearly the same quality, let me know. I am open to suggestions and any help whatsoever, thanks!
First, get rid of the 7800 GT and get a 7900 GT. It performs as good as a 7800 GTX, yet it only costs about $15 more than a 7800 GT. Second, get a cheaper motherboard without SLI. SLI is NOT worth it at all, adding a second card does not boost performance by 100%, it will actually boost it by 20 - 30%. Getting a stronger card will be cheaper, more powerful, and it will have less compatibility issues.
Nice setup, except you dont need SLI. As others will atest on this forum, and Tom has proven, 2 mid range cards in SLI will NOT outperform one high end card. So trade it in your 7800GT for a 7900GT and trade in your SLI motherboard for a non-SLI Asus board. The Opteron is a good choice, and is exactly what I would recommend.
As for the hard drive and RAM, both good choices. If you do plan to overclock OCZ RAM tends to overclock better than other brands and 2GB will be around the same price. (Gold is like $220). As for the DVD-burner, Lightscribe is cool, but it requires special (pricey) discs if you really want to burn art on the disc. If you dont really care about this opt for an NEC DVD burner for $39.
Is this [http://www.newegg.com/Product/Product.asp?Item=N82E16814150139] the card you are talking about? If so, thanks a ton. I can see how by the specs that this card would killa 7800.
What if I got a SLI motherboard, a 7900, and planned on upgrading SLI 7900 later on? I understand games out right now will run very smooth with my setup including the 7900, but when the future comes (over about a year and a half or so) will one 7900 run everything on max settings or near max? I could spit out that extra 80 for a sli mobo no problem, but the main question is, is SLI 7900 worth it in the future? Or in the future should I just upgrade to a better card then? I know that the 7900 card will be cheap then, which is the only real reason that im considering this. THANKS!
Yes, this is an excellent card for the price. You should definitally get it.
If would be a better use of money to upgrade the card when the time comes then get another 7900 in the future. Video card prices actually do not fall that much. Look at the 7800s 6 months from now, they won't be rock bottom cheap. However the 7900 is going to run all games currently or in the foreseeable future very nicely. If you want the best card right now, look at the $600 7900GTXs which have 512MB of RAM (2 GPUs on the same card)
im guessing you already have a monitor, speakers and all that, but im wondering do you have a soundcard or not. if not get one. you get the most benefit out of games if you can immerse yourself in them and sound is essential.
I hear all over this forum that onboard sound is very efficient. If that's the case then I am fine with onboard, it saves me a good amount of cash as well, although i know a soundcard would probably help sound a whole lot.
onboard sound is good for playing basic sound but if you want good surround sound in games and especially EAX effects then dedicated sound such as the audigy 2 range is essential although not straight away. onboard sound should suffice and i really am only meaning suffice for the present. it should not be seen as a replacement and equal to dedicated sound.
"I hear all over this forum that onboard sound is very efficient. If that's the case then I am fine with onboard, it saves me a good amount of cash as well, although i know a soundcard would probably help sound a whole lot."
Indeed, since the advent of 6,7, and 8 channel sound integrated on most mainboards, I've not bought a soundcard since the year 2000!
