I am looking for a front panel fan controller. Idealy, I'd like one that:
#1) Is Silver with Blue LED (I'm flexable to a point on this)
#2) Does not require any additional Tempurature Sensors to be installed (Not a big fan of doing this, though I will if needed). - Idealy, one that can use the onboard sensors of the motherboard for temps. I'm even willing to use one that does not have a display/sensor, though this seems like not a good idea.
#3) Can handle 3 fans, one of which only has a 4 pin connector. - Currently, my Zalman is on a fanmate, but I have that inside the case, something on the outside would be nice.
#4) Is reliable and functional. Idealy one that functions from the front of the case, and not just software.
#5) Idealy, is priced under $50, though if it's perfect, I can go over. Ignore this part for recomendations.
I've been searching, and I liked the Super Flower SF-610, but I can't find it anywhere. Beyond that, there are some debatable ones I'm just not sure if I like or not, so I'd like some recomendations.
Thanks in advance.
Thanks in advance.
