Archived from groups: alt.games.microsoft.flight-sim (
More info?)
The last time I updated my creative drivers (WinXP Pro) there was a feature on the creative site to interrogate my machine from
their website and let the program determine what drivers were necessary from the scan.
I'm not sure if it will work the same with Win ME but here is the procedure to get to the page in question and how to find the
option depending on where you are in the world.
Goto
www.soundblaster.com
Select Support from the menu in the page.
Pick your location in the 'Creative Worldwide' menu that appears which will expand as you select options then select the 'go'
button to the lower right of this.
You should now be on the downloads page and a couple of paragraphs down in the centre you will see the AutoUpdate text link in
blue so select it.
Accept on next page.
When the dialogue box appears requesting to run "Creative Software AutoUpdate" select 'yes'.
If other dialogue boxes appear during this process then select 'yes' to install them.
It should then tell you what you have installed in the machine. If it does select the 'Check Update' button.
Then look for the download for Drivers only in the available downloads page it displays. Should be pretty self explanatory from
there but see note below.
After the update, you will most probably need to reset your machine to complete the update.
Note: that there is a lot of add-on software it may recommend depending on the operating system and what that particular card will
support but just ignore those. They aren't needed.. just look for the driver package it recommends. Also, if you have a firewall
active, deactivate it for this procedure.
If you have no joy there then there are various newsgroups you can try using 'creative' and 'products' keywords.
"Quilljar" <wykehill-flightsim@yahoo.co.uk> wrote in message news
![:D :D]()
78484$dvn$1@nwrdmz03.dmz.ncs.ea.ibs-infra.bt.com...
> Hi Guys,
> This is not OT. I have my grandson age 13 coming to stay in a couple of
> days. I have built him a dedicated FS2004 computer from parts I have been
> given. I have upgraded it to Windows ME ( Don't ask). All is well, except
> that I cannot get the Creative Soundblaster Live card model No CT4780 to
> work. I have installed the correct driver from the CD and looked on the
> Creative site for help and an upgrade with no luck. Neither the sound, nor,
> of course, the game port MS FF sidewinder joystick, will work. I have the
> correct driver and CD for that too. I have taken the card out and put it
> into a different slot, but no joy. Any suggestions or help would be welcome
> as I do want my grandson to have a good experience here, as his parents are
> divorcing and well.....
> Cheers,
> Quilljar
> see
http://client.webshots.com/album/194691959rhDQFi
> Do not reply personally, all such emails go into my spam filter
