Thrmaltake Power Supplies
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Thrmaltake Power Supplies
Are they good? I'm in a position were the only brand name I see is thermaltake, and all other are not known (no antec, enermax, cooler master) but no-name, feather-weight 400W PS.
Any thoughts at all? :cry:
Sponsored Links
Quote :
They are a name brand maker with a good reputation - mostly noted for their cooling products. I have not heard anything bad about their PSUs.
Reply to Bill_Bright
Thermaltake...do they actually make anything? Sirtek makes their power supplies, which are generally high quality.
Reply to Crashman
I have one, it works!
Reply to FlyGuy
yah Tt is a good company
Reply to pengwin
I have one used with great success. Only issue with them is they use 2 -80mm fans, rear variable speed - which is quiet at lower speeds but run fast and very nosiy at full speed. Cooling is no problem with the fan throttles though.
Reply to ms2005
I have one, it works, it is not exuberantly loud by any means, and I love cable sleeving.
The only thing I would ask for would be detachable cables, but oh well...
Reply to russki
I have two systems both have the 430 pure power W0009RU PS in them and have wotked great for years. Very Stable and quite fans.
Reply to cathudog
I have a Thermaltake 480 and to me it runs a little louder than advertised... this isn't based on any formal testing... just my ears. Perhaps it is my case (that will soon be replaced thank god!)
Overall mine has been a great unit... I've got an X2-4400 OC'd to 2.6 GHz and it is rock solid (until it overheats because of my retarded case... argh!) As long as I run the A/C in my room, I have a perfectly stable system so the power supply is definitely getting it down.
Reply to rodney_ws
No, it's not just your ears...Thermaltake's sound ratings are..."a little enthusiastic".
Reply to Crashman
I have the cheapest Thermaltake W0009R / TT420-AD and it has been 100% reliable for over a year powering my Son's PC (Athlon64 3400 / vnf3-250 / 1Gb (2 x 512) / BFG6800GT / 4 IDE HDDs / SCSI DVD & CD / 4 80mm fans) and my linux server (dual PIII 1Ghz / U160 18Gb raptor / 2 x SCSI DVD-roms) on and off for about 6mos each system.
The noise is not so bad considering the amount of air it pumps through the case, I would give them a positive recommendation...
Reply to doolittle
Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Thrmaltake Power Supplies
There are 947 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
