You certainly aren't going to find anything that says "This works on Compaq Presario Models...." You've got to fill in the blanks yourself to figure out what will work. Give me the model and I can tell you for sure!
Ok Ive got this:
Compaq Presario SR1514NX
Form factor Micro-ATX form factor: 9.6 in x 9.6 in
System BIOS Supplier Award
Processor AMD Athlon 64 processor with HyperTransport support
Processor socket type Socket 754
Processor front side bus frequency 1600 MT/s @ 800 MHz
Maximum approved processor Athlon64 3700+ or AMD Athlon64 3400+
Chipset "North Bridge" SiS760
Chipset "South Bridge" SiS964
Memory type PC 2700 or PC 3200 DDR
Memory sockets 2 x 184-pin DDR DIMM
Maximum Memory 2.0 GB
Graphics None
Graphics configuration Up
Graphics connector (AGP) 1 AGP 8x
Audio Integrated AC97
AC'97 CODEC Device Realtek ALC658C 6-channel CODEC
Audio Jacks ( Legend below ) 2M (1F+1B), 2LI (1F+1B), LO, Headphone connector
Ethernet 10/100 LAN supplier Realtek® RTL8201CL LAN PHY Fast Ethernet LAN controller
Ethernet configuration Integrated, Down
IEE 1394 VIA VT6307
IEE 1394 Front/Back Options 1F + 1B
SATA connectors 2 SATA connectors (supports a total of 2 drives, 1 serial ATA-150 disk drive on each connector)
IDE UDMA modes 2 x UDMA 100/66/33
Expansion slots (AGP/PCI/Exten) 1 AGP, 3 PCI
USB ports Up to 6
USB Front/Back Options Up to 2F + 4B
Serial, parallel, floppy, PS2 keyboard and mouse 1S,1P,1F,PS2 K+M
Available manufacturing options ( Legend below ) ULE6
