Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > Been running for 2 months, now encountering a problem
Forum Homebuilt Systems : General Homebuilt - Been running for 2 months, now encountering a problem
Hey guys, I built my first computer in January and I've been pleased with it. However, something weird has been happening and it started like a week ago. Whenever I shut down, the computer is totally dead, like the power button does nothing. However, I flipped the Power Supply switch off, waited a while, and turned it back on and everything works fine.
Does anyone know what's wrong? And will this method screw I'm doing screw up my computer further?
Sponsored Links
could be a faulty power supply or some mobo components not functioning correctly. have you another psu you can try. also re-check all connections especially power connectors including the ones that connect the power switch to the mobo
Reply to strangestranger
No, flipping off the PS power switch after shutdown will not hurt anything...
Just an annoyance, and assuming the PS itself is the first likely suspect....
What are your system specs?
(Just to ensure you are not attempting to run a dual 1900XT rig with an Opty 185 and twin Raptors with a 300 watt PS, etc...!) :-)
Reply to mdd1963
Quote :
lol he'd be lucky if he'd be even able to boot with a 300w
Reply to tehmonker
due to the way it has to be fully powered down i'm starting to believe that it is maybe a capacitor problem. it sounds like the sytem has to be switched off to let any stored charge drain away before it can start again.
I'm running:
ASUS A8n SLI Premium
2GB 2x 1024 Performance RAM OCZ
Two GeForce 7800 GT's in SLI
AMD Opteron 170 Denmark Dual Core Processor 2GHZ
ENERMAX Noisetaker 600W
I also have the Thermaltake BigWater SE for premium coolage.
Reply to Rainer7
There are 1120 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
