Dell Case Problem
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Dell Case Problem
I have a friend who has a case problem. He got a Dell 4300S (S stands for slim) a few years ago. Now he needs a new video card so he can play CIV IV, but the 9800 pro he purchased doesn't fit. It's too long. So does anyone know if the Dell 4300S motherboard will mount correctly in a regular ATX case? If so I can just get him a new case and all is well. I doubt it will be easier to find a shorter video card.
Sponsored Links
That is more than likley a mATX or fATX form factor mobo. The easiest solution would be to call Dell and have them confirm form factor. If it is mATX, then it will fit in a standard ATX case. All else, you can measure the spacing of the screws and see if they match up.
Reply to Rugger
It's like a Fattie, but different...JK - it stands for Flex ATX.
Reply to Rugger
just measure the danm mobo
if tis 9.6 in by 9.6 in its mATX if tis 12 in by 9.6 in its normal ATX
Reply to pengwin
Flex ATX, it's the two-slot form factor shortened from Micro ATX. It fits in ATX, Micro ATX, and Flex ATX cases. Most SFF cases are Flex ATX, though a few are Pico BTX.
Reply to Crashman
Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Dell Case Problem
There are 1298 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
