Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > I'm Done. 1st System Build
Forum Homebuilt Systems : General Homebuilt - I'm Done. 1st System Build
I just finished my 1st build and used SiSoft Sandra Pro06 for the burn in. Then used 3DMark06 to get a benchmark. Here's my system,
Intel 3.2 Dual Core I swiped from my Dell
Zalman 9500 CPU Cooler
P5N32-SLI Deluxe
2- EVGA 6800 GS
3 gigs DDR2 Ram
Case- Thermaltake Kandalf
Without Overclocking I got a 3Dmark score of 4439
Seems a little low to me but I havent turned up the heat yet. I need to do a little studying before I get into this.
Cruizer
Sponsored Links
Hi there.. 3D mark 06 score for your systems if just about right i feel.
2x of 6800GS ... well i am using 1 7800 GT and i get the same score...so maybe if u want a higher score...get a better GFX card maybe...
Cheerz.
Reply to biggy52
Look at my sig for my pc specs... and there's also a link to my current score with an OCed AMD 4200+ and X1900XT... so in comparison... i reckon you have the right score for your rig, IF it has been tested on 3DMark2006....
Reply to Bluefinger
- 0 +
"2- EVGA 6800 GS
Unload both of those for $169 each or so, and get a single 7900GT, pocket the remaining $38 for use at a strip bar or restaraunt, and watch your gaming performance double easily, and at two steps higher resolution to boot...
Reply to mdd1963
There are 695 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
  • 01:00 WookinPaNub won the Uniformed badge
  • 01:00 kwadams won the Uniformed badge
  • 21:57 brockh won the Sophmore badge
