Tom's Hardware > Forum > Computer Peripherals > Printers > Weird problem: Pos printer with PCI add-on card
Forum Computer Peripherals : Printers - Weird problem: Pos printer with PCI add-on card
Archived from groups: comp.periphs.printers (More info?)
I have 2 STAR TSP 200F and 1 TSP2000 (auto-cut,2color) printers. It's
connected to 1 build-in (LPT1) port and 2 parallel printer ports using
a PCI add-on card from SUNIX. The card is recognised through the
command line PCIDOS /AUTO in the Autoexec.bat. When I connect any of
the mentioned printers to the add-on pci printer card the printer
turns itself in to offline and when unplug it, it will turn back to to
online. This does not happen with LPT1. I tried to connect some normal
printers (HP 560C, 960C and Star 24 pin Matrix printer) and it works
fine. MSD in DOS it confirms 3 LPT ports. I have another network
working with the same printers connected to an ISA add-on card and it
shows no problem. Why can't these printers work with PCI add-on cards?
I have no ISA ports on my new computer. The OS is DOS.
Sponsored Links
There are 533 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
