Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > Help with homebuilt system
Hi
i need some help. I want to build my own gaming rig and it wolud be nice to hear your opinions on what I plan on getting.
Motherboard:
MSI K8N Diamond Plus Socket 939 NVIDIA nForce4 SLI X16 ATX AMD Motherboard - Retail
http://www.newegg.com/Product/Prod [...] 6813130037
Processor:
AMD Athlon 64 X2 4800+ Toledo 1GHz HT Socket 939 Dual Core Processor Model ADA4800CDBOX - Retail
http://www.newegg.com/Product/Prod [...] 6819103544
Ram:
CORSAIR ValueSelect 1GB 184-Pin DDR SDRAM DDR 400 (PC 3200) Unbuffered System Memory Model VS1GB400C3 - Retail
two of them for 2 GB
http://www.newegg.com/Product/Prod [...] 6820145505
Hard Drive:
Seagate Barracuda 7200.8 ST3250823AS 250GB 7200 RPM Serial ATA150 Hard Drive - OEM
http://www.newegg.com/Product/Prod [...] 6822148065
And a geforce 7900GT graphics card.
So what do you think?
Is everything compatible?
Will I be able to use DX10 if I replace the video card with a DX10 card when they become available?
Thanks
Sponsored Links
I would get a matched dual-channel pair like this Patriot 2Gb CL2 for $200 w/ a $50 MIR - but today is the last day on the rebate. I just got my second pair this weekend... Works well in my EVGA SLI mobo w/ X2 3800.
Reply to doolittle
Whats the difference between paired and not paired ram?
Reply to juan_mol
Matched will be more stable when running your memory in dual channel. Seperate question do you plan to overclock? Cause if you do the DFI mobo's would be a better choice, as well you might want a little better ram such as corsair XMS series dual channel kit.
Reply to baracuda73
I'm not really planning to overclock. I just want to get the best system possible. I know a lot about computers but there are so many different manufacturers today that it gets confusing, and I got little experience when it comes to building PCs.
I just want your opinions on which components to buy, if they're all compatible and the best manufaturers.
Thanks
Reply to juan_mol
If that is the case you have a pretty nice system planned out.
Reply to baracuda73
Direct X 10 will probably not be available for WinXP OS, but only on Vista, but I'd expect 7900 series cards are probably already compatible with Direct x10 feature set...
I'd probably save another $75 or so, and get the X2/4600+ instead...same 2.4G, just a smaller cache, and quite similar gaming performance....
Reply to mdd1963
"and the 7900 will have support for Vista, so you shouldn't worry."
"Support for Vista" is rather misleading, and is not quite the same as saying "supports Direct x 10"; Vista will have less stringent (Direct x 9, 8 etc., )rendering solutions for older video cards as well...
Many video card makers are touting their "supported by Vista" advertising labels, but I don't see many yet saying they "support/implement Direct x 10", curiously...
Reply to mdd1963
my rig is nice!
Reply to gahleon
If you're willing to OC, that would save you some money. Keeping the same mobo, get a Dual-Core Opteron instead, and OC the hell out of it. It's possible to just get a $40 CPU Heatsink and OC a 1.8Ghz Dual-Core Opteron to Athlon X2 4800+ levels. With that saved money, you could get a RAM upgrade to 2GB.
Reply to steveosazninvazn
Steve tell the truth!
Reply to gahleon
There are 1040 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
