Problem installing 7900GT (twice)
Ok here's my scenario.
I have a MSI K8N Neo4-F. Everything runs perfect with my 6800GT installed.
I buy a 7900gt(EvGA, superclocked). It posts, etc etc, and never gets into Windows. I do a hot restart, and it says windows didnt shut down properly, blah blah blah. Safe mode does the same thing, cannot get into even an ultimate boot disk windows environment.
I call NewEgg, they RMA me, I buy a different card, XFX. I put it and the same thing happens. I just finished updating all my BIOS levels (was down by one, and it was nothing serious) and I cannot figure out what the hell is going on.
Is it possible I got 2 bad cards? Is my luck that bad? Is it a mother board incompatibility? Nothing else really jumps out at me about the sitution.
Again I can get through Post just fine, just nothing VGA wise ever goes through.
7 answers Last reply
More about problem installing 7900gt twice
  1. Could be the power supply - what rating are your 12V rails? The 7800 uses more power than the 6800, especially a slightly overclocked version. I was running a 400W PSU with particularly strong 12V rails, and the card is rock stable at stock, but I did suffer from reboots when overclocking to 450/1100 and above - now its strong with a new 600W Seasonic :D
    Might be worth ripping the nvidia drivers out as well and reinstalling from scratch...fixes things 9 times out of 10!
    Matt
  2. I'm not sure if we have the exact same problem. I get nothing on my screen at all. Everything sounds normal, though. It sounds like everything boots up just fine. I just can't see anything. I can't go to bios, safe mode, etc. Because I can't see. Monitor power light blinks as if in standby. And the fan on the card runs. It just seems like there is no signal being sent to monitor.
    I doubt mine is a power issue. My psu is only 460w, but it has 34 amps on the 12v. That should be plenty. This pc is a Dell Gen 4 XPS. I've heard people on the Dell forums say they are running 7800 and x1900 cards in the same XPS model that I have. Both of those need more power than the 7900 cards.
  3. minimum power supply required by man.
    A 350W PCI Express compliant system power supply (with 12V current rating of 20A or more)
  4. I did manage to get mine working... which makes me feel bad about returning the first card... oh well.
    Still not entirely sure what the problem was since I did all the fixes I could think of remotely while at work, and than tried it when I got home.
    But thanks for the input!
  5. What were the fixes that you did? Just curious, since my replacement card (eVGA 7900 GTX) should be here today. I hope I don't have the same problem. But, if I do I'll know it's not the cards.
  6. I did an update on the BIOS (twice just make sure it was ok)
    I did a complete removal of all current graphics drivers.
    I switched out the 12v Power cable for the card
    I reseated it at least 15 times.
    I mentally willed it to work (this was key)
  7. Yep, mine was definitely a bad card. I don't see any other explanation. My new card, an eVGA 7900 GTX, arrived today. It installed flawlessly. I did absolutely nothing different. I only had to move my sound card to another slot. Otherwise the big cooler on the GTX would have been just under it. I thought more breathing room was better.
    So far, the only games I have tried with the new card are FEAR and COD2. My performance in those two games has literally more than doubled. I'm very happy with this card so far.
Nvidia Graphics
